Where can I find a new inner port hole lining
8
oday 32 Toronto Island
One of the clips on my 32 Oday port holes broke. I need the whole inner window and 2 clips that hold it shut. Can anyone tell me if you can buy them. The frame is black and the window is black and oval and about 16 inches wide and 6 inches high.
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
Hi Ed,
It sounds like you need a lens and two dogs. Check the inside of the port, lower left corner, and see if you find a stamp that says Gray Enterprises. If so, we can provide those for you. 877-932-7245.
Sep 25, 2008
992
Oday 25 Gibraltar
If it's a beckson you should be able to buy replacements. Check their website
Rich
Jul 4, 2011
8
The lens is fine it's the "dog" if that's what it's called that broke which is attached to the black frame. There is no name on it but I do have a pic which may not tell you much. The clips are a metal screw with a spinning toggle on it that turns to loosen and then clips over the black protrusion out of the frame.
Jul 4, 2011
8
No brand name-there is a screen on the outside and a black rim that extends out and inch with two slots in the bottom. I don't need the outside part just the inside. The two dogs are attached to the black frame.
Ritdog
Jul 18, 2011
184
Oday 25 Portland, ME
Try www.massmarineparts.com - they are a boatyard in Quincy, Mass that also breaks boats (sad to see...) they have a HUGE inventory of all kinds of power and sail parts, at about a fifth of list. Used, yes, but you can look around the yard and pick out what you want. Jon the owner is hard to get hold of, but try the # on the site. We got about $1400 of stuff there in March for $225, for our Oday25.
