When to tighten keel bolts (if ever)?
Nov 27, 2013
10
Hunter 28.5 Lake Perry
We are refinishing the sole in our 28.5 and that process has 'revealed' the keel bolts. Is it sensible to tighten them while they are available? It's an 87 and the keel bolts have probably never been tightened. There is no leakage--should we tighten or leave well enough alone?
May 1, 2011
5,556
Pearson 37 Lusby MD
Others who have Hunters will chime in . . . I had the torque checked on my keel bolts during my last refit. All 9 were uniformly a little loose and required 1/4 to 1/3 turn to bring them up to torque of 124 ft/lbs.
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
And if one were to check/tighten their bolts.....
Would it be better with the keel "hanging" in the water...or with the weight of the boat on it on the hard...?
May 1, 2011
5,556
Pearson 37 Lusby MD
My boat was on the hard when the keel bolts were re-torqued.
576
Island Packet IP31 Lake St. Louis, Montreal
Chances are very good that, when the factory originally tightened the keel bolts, the boat was sitting on land.
Matt
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
The bolts have to be tightened with the keel sitting on the ground. I think it would be a good idea to check the torque of each one. Things do settle and stretch with time (ask anyone over 60 years of age ! :D).
Bob
Nov 27, 2013
10
Appreciation
Bob
Thanks to all of you for taking the time to respond and advise. This was my first "inquiry" and I was pleased with the tone and thoughtfulness of the answers. Thanks, guys, I hope sometime I see a question even I might have an answer to!
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I have an '86 H28.5. There is no evidence of keel bolt leakage. My advice is to leave well enough alone unless you see some signs of leaking around the bolts.
Feb 6, 2013
437
Hunter 31 Deale, MD
So....where would I but a 2 1/2" socket that would fit my 1/2" drive torque wrench?
Mar 19, 2013
10
Hunter 27 Kelowna
if the socket is truly 2 1/2" you will need a 3/4 drive reducer to a 1/2 drive torque wrench. 2 1/2" seems very large for keel nuts or bolts.
May 16, 2007
1,509
you may also need a torque multiplier and an extension............,maybe better to hire a mechanic to do the job,
if the keel really has 2.5" nuts you probably would need to go up 1" drive deep socket, try McMaster-Carr for something this size
Bob
FredV
Oct 16, 2011
148
Hunter 37-cutter Philadelphia, PA
Does the 124ft/lbs of torque apply to other Hunter models as well, like the 37C?
Thanks.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
I might be slow but I did heed your advice to check my keel bolts on my wing keel. Those of you who have Cat 250 fixed keel bolts beware! My bolts were indeed loose and a couple of them a turn or so out! This boat is a 1998 and hardly used and first dip in the ocean in September, heed the warning! Thanks Guys, you saved my rear. Chief
May 16, 2007
1,509
From Hunter:
Keel bolt sizes.........Socket size........... Torque
3/8"........................9/16"...............21 foot pounds
1/2" ........................3/4"...............45 foot pounds
3/4"........................1-1/8".............132 foot pounds
1" .........................1-1/2"...............325 foot pounds
1-1/4".....................1-7/8" .............546 foot pounds
Models Number of studs & size
H336 5 x 3/4", 1 x 1/2" and 1 x 3/8"
H340 2 x 1" and 3 x 1-1/4"
H356 2 x 1/2" and 6 x 1"
H37.5 7 x 1" and 1 x 3/8"
H37.6 7 x 1"
H40.5 3 x 1"
H410 7 x 1" and 1 x 1/2"
P42 & H43 7 x 1" and 1 x 1/2"
P450,P456 & H460,466 and 46 7 x 1"
H49 9 X 1" (some keels have 9 x 1" plus 1 x 3/4" aft)
Nov 27, 2013
10
Appreciation
Bob, much appreciated and helpful. JL
From Hunter:
H37.6 7 x 1"
H40.5 3 x 1"
