When to replace vs. repair sails
1,511
Hunter H46LE Sausalito
this winter may be a very good time to buy
I've found that sail lofts are usually willing to make deals during their off-peak seasons. With the current economic downturn, it seems almost certain that lofts are going to be offering fabulous discounts once we get a bit closer to Christmas. You'll probably be able to get a custom sail as inexpensively as you'd normally pay for a made-in-China one size fits all sail. And that's going to result in a huge performance difference over an 18-year-old OEM sail.
Huge.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
Tighten
Tighten up the halyard, the luff is sagging.
Release the mainsheet. If the wrinkles go away you may need to have a rigger look at you stay tension. If cinching down the mainsheet produces wrinkles it may mean that the sail is pulling the masthead aft, which means the headstay needs tightening.
May 6, 2004
916
Hunter 37C Seattle
I see a slack luff/boltrope. Lube the luff track, slack the sheet and vang and crank the halyard so its banjo string tight. Try that before everything else.
Cappep
Pearson 303 Penetanguishene ON
The problem that I have with older sails and especially ones that are blown out or have too deep a draft, is that as soon as the wind picks up there is too much drive in the sail and the boat will tend to heel more and not drive to windward. Off the wind it can be great but most of us need to go upwind at some time or another. It may be neccessary to reef earlier to keep the boat on it's feet.
Besides, new sails from a good sail shop, look and feel good.
Happy sailing
Charlie
Feb 6, 1998
11,759
Just a thought...
From looking at the picture it appears that you have too much vang tension. The leech seems really tight and a tight and is showing signs of "hooking". The tight leech will prevent a full hoist of the main. Try releasing the vang, the main sheet and the out haul then adjusting the halyard and re-adjust everything else after you have achieved full hoist.
I think you may find, if your halyard spice is not binding in the mast head, that you will be able to get a decent shape out of that sail..
Perhaps you've tried this but from the photo that's all I can offer..
As for new sails that's a personal decision and every one has a different standard for "dead" sails...
RichH
Feb 14, 2005
4,773
With no intent to offend, your sail simply isnt raised properly.
You havent 'stretched out' that boltrope ... and the sail will be 'baggy', draft aft (the pic shows it), the leech beginning to 'hook to weather' (it is).
A CAt 30 mainsail has the following dimensions ( to see if the boltrope has become shrunken) ... A boltrope 'usually' has to be 'eased' after about each ~200-300 hours of 'hard' sailing:
***** Luff 35*ft (10667mm)
Foot 11.5*ft (3505mm)
Leech-AftHdBd 36.22*ft (11039mm)
******* Tack Angle 88 deg. angle that the ''cloth side''' of the boom makes with the mast !!!!
Diag (clew/head) 36.46*ft (11113mm)
Head (inches) 5.25*in (133mm)
Area (no Roach) 207.78*ft2 (19303mm2)
For a Cat 30 with 35ft. luff ... release vang, mainsheet, outhaul, topping lift, etc. ... completely, then raise the sail so that its 'just up', then (important) apply THREE extra inches of halyard strain.
Measure the angle that the sail side of the boom makes with the mast --- should be approx 90 degrees (88 actually) - just use a large sheet of paper/cardboard.
If with 3 inches of 'extra strain' that angle at the tack of the sail is GREATER THAN 90 degrees (and the aft end of the boom is lower than the gooseneck (with the mast 'straight up') ... then the sail has a shrunken boltrope. Sometimes you can add EXTRA halyard strain to make the correction (to tack angle at 88 degrees). If greater than 90 degrees and the aft end of the boom is lower than the gooseneck ... take the sail to a sailmaker, get an evaluation of material condition and if OK, get that bolt rope eased. Most times, if you have a shrunken boltrope, that correction will do 'wonders' for the shape of an old sail.
Your pic shows the luff being quite loose probably by not correctly adding that halyard strain (or use of a cunningham if you have one).
Symptoms of a shrunken boltrope:
• aft end of the boom lower than the gooseneck,
• boat heels excessively but isnt 'fast'.
• leech begins to 'hook to weather' ... a curve towards windward at the aft end of the sail
• 'baggy' - LOTS of draft.
Anytime a sail develops 'girts' (creases) ... it means that one of the three sides of the sail doesnt have sufficient strain or has too much strain .... with the other two in reactance. Anytime you adjust ONE edge of a sail, girts will develop unless you ALSO adjust the other two sides. Did you leave your vang tensioned when you raised this sail when you took the pic?
A sail with a BOLTROPE is made with the boltrope purposely shortened by the sailmaker (usually 1" of shortening for 11Ft. of luff length) .... and the sail wont 'set' (at up to 15 kts.) unless you remove this 'preload' by halyard, etc. tension (... and then make various sail tension adjustments until the helm almost loses most of its 'weather helm').
That 35ft. listing of your Cat 30 luff dimension is 35 ft. **minus ~3 inches** so you have to give such a sail 3" additional halyard strain so you get the 'full hoist' and stretch out that boltrope so that you 'can' have a 35 ft. luff length. Without removing the boltrope 'preload' by the proper halyard strain, and if you only 'just raise', the aft end of the boom and the sails clew will be approximately 3 inches LOWER than the 'design' of the sail ... and the sail (in 15 knots of wind) will be draft-aft, baggy or at maximum/excessive draft, battens will easily 'hook to weather, etc.
General - Typical boltroped sails are 'preloaded' by 1" for every 11 ft. of luff length. Look up the luff length in ft., divide by 11 ... and thats how much 'stretch' in INCHES you should add with the halyard.)
Try the additional halyard strain, then see if other 'anomalies' are present before you make any decisions. Sometimes you need to add MORE halyard strain if the boltrope HAS developed a lot of 'shrink' ... if the shrinkage is too great to correct with a winch; then, you need a new sail or a sailmaker to 'adjust'.
If you do buy a new sail, get a steel tape measure that is longer than the sail luff... measure and RECORD that luff length and then youll know when that boltrope needs to be eased in the future.
ALSO.... when getting a new sail with a boltrope, ask the sailmaker to apply extra length of boltrope ... and 'store it' at the top/head of the sail (on the 'headboard'). Then, if you need to ease, that extra length is already 'stored' and such a job then becomes very fast and very economical (also ... then an easy DIY project using waxed sail twine, a sailmakers needle and sewing palm).
Add that extra halyard strain and measure that 'tack angle' ....... .
No other 'faults' that I can see from the 'pic'.
Not to worry, probably 99% of all those who 'cruise' dont know how much to 'raise' a mainsail or other boltroped sail. They usually 'just get it up' and never stretch out the 'preload' to the sails 'design dimension'.
Next time out, count the number of boats that have 'droopey' aft ends of their booms - never stretched out the boltrope!!!!! 99% !!!!!
hope this helps.
Jun 19, 2004
512
Catalina 387 Hull # 24 Port Charlotte, Florida
Oh No, Don't Tell Me I Hit The Jackpot
If you've never had new sails on your Catalina you will be amazed how well she sails and kick yourself for not buying them sooner.
I've just bought a new loose footed main and a 135% genoa for my C&C 26. Cost was $3,200 from a local sailmaker (I haven't got room to loft a full sail or I'd make my own) so you should be able to get a full suite for less than $4000.
Sam Salter
C&C 26 Liquorice
Ghost Lake Alberta
I found on the Classifieds here in the gear for sale, a brand new never unflolded since it was made, still in the box never opened since it was sealed at the Catalina Factory a 155% RF Genoa for my 387 for $750. I better keep an eye out my front door since the police ought to be showing up soon :D:D:D
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Fox-
When you hoist the main, you should generally tension the halyard until a small amount of vertical creasing occurs near the luff. Then when you tension the outhaul, the creases should disappear.
