F
Frank
Last fall I purchased a "project" boat, a 1978 Oday 30 that had been sitting around for about four years, lots to do! The boat came with an aftermarket wheel pedestal which I have to remove to grind out & reinforce the floor, as this is a small cockpit I'd prefer to leave it off (anyone looking for a wheel assembly?)and return to thetiller. Which was the long winded way of getting to the point here,which is, does anyone haveor know where to get the throtle and shifter cables and levers to mount to the side wall in the cockpit (I can see where the original mounting hole was glassed over)? The boat also came sans boarding ladder, stern mounted four step swing up type, so same questions as above apply. Used would be preferred as like with mostprojects this one is getting more expensive than originally envisioned.Thanks, Frank
