Wheel to tiller
Jun 28, 2009
2
2 27 Bohemia River MD
I have a catalina 250. Would like to replace the wheel with a tiller. Can I just use the emergency tiller connection with a longer tiller?
May 1, 2011
5,270
Pearson 37 Lusby MD
Maybe. I'd be concerned about having sufficient leverage in using the rudder. I assume you have a helm pedestal, so you'd need to remove that, too.
Nov 8, 2007
1,607
I think a tiller is better up to somewhere around 30 feet. So I agree with your concept.
But our tiller post comes up over the level of our cockpit seating. With some rise in the tiller shape, that means the tiller is over the knees of the helmsman/woman, and of others seated in the cockpit. Emergency tiller posts tend to end close to the cockpit deck - not very convenient for steering through a couple of hours or more. If your emergency tiller does not rise to your knee level, you will have to design a strong and reliable extension that will connect securely to the head of the emergency tiller. Certainly doable, but not an easy thing to design or fabricate, I guess.
Joe
Jun 1, 2004
8,259
The good news is that there are many, many people who think wheel steering on a small boat makes it look more expensive and they always enquire here about making the conversion.... that means you'll have absolutely no problem selling your wheel system to one of these people. Now, the not so good news. Installing a tiller sounds simple, if the tiller and rudder post are close to a workable position. Fabricating an extension to the post if need shouldn't be that bad, if you need more height. The traveler location is always an issue where tillers are involved, so you'll need to think that out. It would be nice to see a tiller equipped version of your boat. By far the biggest expense will be the piece of hardware that connects the tiller to the rudder post. On my 45 year old catalina that piece can be purchased for $500-600.:yikes: But, I'd guess you'll find a more reasonable alternative.. good luck.
Sep 17, 2022
157
Catalina 22 Oolagah
rscotto:
As a person who is just coming back to using a tiller on a new to me New Design C-22, I sure do miss my wheel on my 1974 C-22. I'm sure I will get accustomed to it but the tiller sure takes up a lot of space where as the wheel made for a much cleaner cockpit. I might just need to order up a tiller with more lift to bring it over my knees as David in Sandusky described.
George
