Wheel Steering
G
greg
Can you change from tiller steering to wheel steering? If you can what would be approx. cost?
Rick D
Jun 14, 2008
7,206
Yes, You Can. Just $$
Figure a couple of thousand dollars. The gear isn't cheap. You may find it useful to search this sight for tillers/wheels, etc. There has been a lot of discussion on the subject. It is likely to be cost-prohibitive as it relates to the residual value of adding the system. It is pretty straight forward as to actually installing it, but there is plenty to do. RD
Dave Emery
Wheel Steering Retrofit
Check out www.edsonmarine.com they have several retrofit kits.
