You must mean the 272 standard version. The LE version is equipped with wheel steering from Oday.I own a 272 with tiller steering. I think that there are a couple of other 272 owners who were contemplating switching over. If noone responds to your post, check the archives.$$$$ is right to do the makeover.Tom
on this forum. It came up to around $1,500.00 DIY or around $2,500.00 if the yard does it.Along with my post was a list of all the hardware you will need along with the Edson kit.Cheers,Bob
I have a 272 le and I can say that if there ever was a boat didn't need a wheel ... it is a 272.The wheel add-on limits [cuts down] the range of the rudder and there are times ... like trying to back out of a slip to starboard ... where it would be a lot better to have a little more rudder than the edison add on provides.Before you spend the effort, time and money ... find one to sail on and try to see how it handles at a dock or in tight quarters at low speed. If you have one it's fine ... but to go though all that effort ... VicSeven
