Wheel Steering
Robert Wilbanks
I recently bought a catalina 27 '80 model. It is a very nice boat but I would like to have a wheel steering system installed. I have gotten a quote but it was almost half of what I paid. Is this a weekend job for a do it yourselfer'? I know I have to reinforce the deck and the good news is that my traveler is over the cabin. Ideas?
L
LaDonna Bubak - Catalina Owners
Don't
This has been discussed thoroughly before so you can check the archives but here's the long & short of it. Installing a wheel system is (as you've found out) extremely expensive and keep in mind that you will NEVER get your money out of it. They're also more likely for failure than a tiller - granted it's not a frequent happening but have you ever heard of an emergency wheel? Nope, it's always an emergency tiller - for a reason. It also will take up a lot of room in the cockpit, whereas a tiller can simply be pushed out of the way when not in use. Also, tillers have a great "feel" for what's going on under the boat that wheels don't have. Here's the big question: Why do you want to convert? Are you just not used to the tiller? If that's the case, believe me, you'll get used to it in a hurry and will probably end up liking it better than if you had installed the wheel. LaDonna
K
Kevin McGrath
Tiller
Keep the tiller. It will give you better control for a boat that size.
W
Willy
Wheels are overrated
I owned an O'day 27 with a tiller for 9 years. I traded up to a C30 and one of the items on my list of wanted options was wheel steering, be careful what you wish for... I primarily single hand and the wheel complicates the process. It's hard to move from behind the wheel to get to the jib and main sheets. With a tiller it was nice to place the tiller between my legs, steer into a tack and have a jib sheet in either hand. Very functional. Also, autopilots are cheaper. The big advantage to a wheel is having the engine controls and the compass mounted on the binnacle. Also, resale is easier because a wheel is more popular, though now I'm not sure why. Keep the tiller!
Rob Rich
Had the Same thought....
Glad I stayed with the tiller. Initially, a wheel looks better, but like Kevin McGrath said, there is no feeling like a tiller. Wheels aren't altogether bad - in my opinion, on a C-27, they're just not as good. Rob
C
Chris Gonzales
Better feel with a tiller
Over the years I had a Capri 25 and Catalina 22, both with tillers. Eventually I purchased a C25 with a wheel. I was so excited to FINALLY have wheel steering. It was goinf to look and feel so COOL. The fact was, though, that I quickly found I didn't like the feel of it at all. You just can't feel the boat through a wheel like you can a tiller. Also, I didn't like the room the wheel took up in the cockpit and I prefered the tiller with an extension when sitting high on the weather side. I now have a C30 with a very nice Edson wheel. It came with the boat. But if it didn't have the wheel I certainly would have purchased her anyway. I suppose wheels are great for large boats but on the 4 I have owned, including my 30, I opt for the tiller! My suggestion is to sail your 27 for a while and get used to handling her with the tiller. Then steer a buddies boat that is wheel equipped. Bet you feel the same way about the tiller as many of us do after that. Let us know what you do. Chris
michael w
LADONNA'S RIGHT
I ALSO HAVE A 80' C27 AND I LOST CONTOL BEACAUSE THE CABLE CAME OUT OF THE "CLAMSHELL".(well that's what i called it). AND TRYED LIKE HELL TO GET THE WHEEL OFF. NOT AN EASY TASK IN 4-6FT SEAS.STEERING WITH THE "EMERGENCY" TILLER,WAS LIKE ARM WRESTLING A CRAZED B-12 INDUCED LIMEBACKER!.ALTHOUGH NOT HARD TO FIX,BUT WASN'T EASY TO ADJUST AT THE DOCK EITHER.I AGREE WITH LADONNA IT TAKES UP ROOM IN THE COCKPIT,AND EXPENSIVE.I HELPED A FRIEND INSTALL AN EPSEN IN HIS C30.IT PROVED TO BE A SERIOUS PAIN IN THE BOAT!TWO WEEKENDS LATER,IT WAS DONE.AND WERE STILL FRIENDS!. GOOD LUCK AND HAPPY SEAS.
