Enough Power
Dick,I fitted the Autohelm 6000 with the chain drive. It all went into the steering console and there was room for a large sprocket on the fwd end of the wheel shaft.The installation has been well nigh perfect in operation but sometimes I wonder how it could cope with the loads.My concern with the belt type is that the belt might not be capable of holding the boat on course when broad reaching in strong winds.My drive motor is on the shelf inside the console and occasionally I have had it deflect enough to cause the chain to jump on the small sprocket. Since then I have fitted stiffeners between shelf and steering shelf.I cannot visualise the smaller pilot having enough rigidity in its mounting bracket for use at times when you really need it.Kind regards,Don
