Possible solutions
Hi Matt. I spoke to both Hunter and Raymarine regarding your situation. First of all, it is clear that we would have to cut a hole in the fiberglass console for the S1 wheel pilot. The only way around modifying the console is to go with a below decks autopilot at a significantly higher cost.The bigger challenge is fitting a rudder reference transducer in that steering system that is sandwiched on all sides. There is very little room to work with. I'm sure we could come up with some kind of solution by modifying something, but the labor will start to get quite high.I did hear from Raymarine that they are working on new software for the S1 wheel pilot that will allow it to be installed without a rudder reference transducer. They said it would be about a month or so before that is ready.I guess I will call you some time soon to discuss your options.Thanks,RyanMarine Technical Services
