What's under the fuel injectors
NCBrew
Feb 22, 2010
79
Hunter Hunter Legend 35.5 9335 Albemarle Plantation, NC
What parts (I need numbers) goes under the fuel injectors
May 27, 2004
2,059
There is a master Yanmar engine parts catalog available online. I don't know how to post my "soft" copy on the forum.
See private message I just sent.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
So the parts you are looking for are listed in either Figure 16 or FIgure 17 for the Cylinder Head. I assume you have taken the injector valves off and are looking at what is inside the 3 holes. First, make sure you are asking about the correct Figure. There are 6 models listed as follows:
Fig 16 includes: 3GM30, 3GM30VE, 3GM30B, 3GM30C
Fig 17 includes: 3GM30F, 3GM30FVE
It appears that both figures have the same order and listing of parts, but they just have a different sequence numbering system (not the part number)
The diagram shows in order from bottom to top (just under the injector valve) with the number of parts needed
  • 124950-11450 Gasket, Chamber (3)
  • 105311-11420/105311-11430 Chamber, Rear/Pin (3) - this was 2 parts to the component
These parts (above) are captured inside the cylinder head, I believe, and won't be replaced if you aren't taking the cylinder head apart.
I didn't order those components. What I did order and replace are the parts listed below (I was able to extract the old parts with dental pick):
  • Chamber Gaskets (again) 124950-11450 (3) I think these were copper washers.
  • 128275-11410 Chamber, Rear (3) These little buggers were $15.12 a piece
  • 128275-11490 Insulator (3)
  • 128275-11500 Cover (3)
  • 24341-000260 O-ring (3)
I spent $93 for these 5 parts.
Then the injector valve goes over it all.
