What's this on my Cal 20?
7
Aloha,
Can anyone tell me what this bracket is for on the back of my Cal 20's mast? I recently bought this Cal 20 project and am getting close to putting the rig back together.
Thank you
10,048
Maybe where two roller feeders go to feed the luff to the mast track?
Wider angle picture?
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
without a wider view of where it is on the mast, it is hard to say. It doesn't look like a gooseneck fitting that I've ever seen, so I don't think it is how the boom attaches to the mast.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
I would guess that the boat once had one of those roller furling mains that are like a roller jib with the wire stretched free aft of the mast. They are quite inefficient so it would be no surprise that it was removed leaving only the bracket.
Nothing else I can think of makes sense with the proportions and geometry.
Tim R.
May 27, 2004
3,626
It appears stock. Have you checked with any other Cal 20 owners?
3,504
I Have Not Sailed A Cal 20 for about 30 Years but,
I am pretty sure it is (was) a feeder for the main sail
Aug 2, 2005
374
pearson ariel grand rapids
I'll go with part of a gate or feeder for the track to prevent the sail from dropping out when it was lowered, Number one reason I've always disliked that style mast.
Ken.
Oct 25, 2008
7
Thank you for all the replies. I have looked at many Cal 20s and have not seen any with this part. Roller reef or Roller feeder....I'm going to assume that I can just leave it there without using it.
Thank you
Nov 6, 2006
10,048
Yip, I think it had some kind of lazy jack system which let the luff fall out of the track for stacking but would feed it back in the track when the halyard was taken up. The sail probably had a wire or rope luff, instead of slides. Looks like axel holes to hold the feeders.
Pearson 26W Marblehead
Part on Cal 20 Mast
Since the consensus of opinions agree its a sail feeder, and you have decided not to use it
Your probably going to need a sail stop on the lower part of the track to prevent the main sail
from dropping out of the track every time you lower it. Unless your going to remove the main
sail every time you use it
Tim R.
May 27, 2004
3,626
Wahiawa, does your boom pull out away from the gooseneck and rotate? A lot of smaller boats that have a bolt rope luff main have a boom that allow you to reef/furl the sail. That device, as other have pointed out, is likely a guide for the luff to go into the track.
Bffatcat, a main with a bolt rope luff when lowered comes completely out of the track. There really is no way to prevent that with a stopper. If it has slugs than a stopper would work. I have owned 3 boats with the roatating boom and luff tape on the main.
RichH
Feb 14, 2005
4,773
This is probably part of the multi-lead cunningham downhaul system. The "lugs" at the end of the brackets are probably for mounting sheeves, through which sail control lines are attached.
Such a cunningham downhaul system is useful in bringing the position of maximum draft in the lower section of the sail forward, primarily its used to get the boat to 'almost' a dead fish' neutral helm (very very slight 'weather helm' felt in the tiller); but, at much higher wind speeds can be used to radically de-power the mainsail (instead of reefing).
The cunningham system works something like this:
The mainsail sail should have a grommet/cringle (reinforced 'hole') behind the luff about 2-3ft. high from the tack/gooseneck. A stainless U shaped 'strap' goes through the grommet and has small 'bullet blocks' at each end of the metal strap; the 'control line' connects to the strap via the blocks at the lugs.
The control lines can be adjusted while sitting on either side of the cockpit. The sequence of the 'course' of the control line is probably - from one side of the cockpit to the separate "control line bridge" (over the companionway) to a block mounted on one of the stubs on that 'mast fixture, back down to a block mounted at the base of the mast and back to a block mounted to the other stub end, back to the control line bridge, and to the cockpit on the other side. Plenty of mechanical advantage to pull the cunningham downhaul and easily reachable by the crew and/or helmsman ... plus the mechanical advantage makes adjustment easy when the sail is heavily windloaded.
Cal 20 also used a 'Barney Post' - essentially a 'pipe stub' that was mounted on the floor of the cockpit that 'stood up' about 8" ... many of the control lines 'came up through' the Barney post and thence to the control line bridge. I dont know if the cunningham downhaul terminated in the 'barney post' on a Cal20.
The alternate possibility is that these stubs will have blocks attached; but are used to control/tension the barberhaulers. The barberhauler was principally used to adjust the distance of the 'slot' opening between the mainsail and the jib (instead of using athwartships fairlead cars). After all sail set and trim to perfection is accomplished, then when on a beat one would typically pull in the barberhauler (attached to the jibhseet at the clew of the jib) until the boat reaches maximum speed and begins to point much higher than when the jiblead/fairlead is simply at the rail. The lighter the wind the more you will 'bring in' the barberhauler, the higher the wind the 'more open' the slot.
Both barberhaulers and cunningham downhauls were common on the Cal20 (and other Lapworth designed boats).
Hope this helps.
Oct 25, 2008
7
Wow!! The boom does in fact pull out and rotate!
I guess I have a roller reef boom. I was wondering why the main that came with the boat didn't have any reefs on it. Now the hunt is on for the rest of the luff guide.
Mahalo
