What's this called?
Oct 9, 2018
21
Hunter 28.5 Annapolis
So I was doing some testing and playing and figuring things out... well nothing good can come of it. Broke the hook that holds my vang to the mast.
my problem, whats it called?
6,017
Oday 322 East Chicago, IN
Are you saying that your “dang vang“ used to be mounted to that plate?
Why not just rivet it back on the plate (or use some short bolts)?
Or if it was a hook / loop of some kind, you could put a u-bolt into those holes and put nuts on the back.
Otherwise, maybe check rigrite.com
Send them a photo and they can tell you what it is called. They do custom fabrication if needed.
Greg
Dec 2, 2003
766
Hunter 260 winnipeg, Manitoba
Looks like it had a ubolt welded to the plate? You could remove the plate and take to a machine shop or welder and have them weld a new piece of stainless rod bent to the appropriate shape to it.
Likes: Ozpilot414
JBP-PA
Apr 29, 2022
838
Jeanneau Tonic 23 Erie, PA
It's called a diamond pad eye. Normally mounted on deck, but that was modified for your vang. An oblong pad eye instead of a diamond base should work fine too.
Likes: Ozpilot414
