Shell Rotella 10w-40
At the risk of starting a brand war ...Universal called for 30w in the early manuals, then changed the spec to 10w-30.I use Shell Rottela 10w-40 in mine. It is a HD oil rated for diesel service and has no friction modifiers.One problem than can happen with modern automotive oil is the high fuel economy rated stuff. It can contain friction modifiers than play hell with the clutch in both Atomic 4 and motorcycle engines. (I use Rottela in my motorcycle for that reason)If your engine is in good shape (about 100-105 psi compression), it should be happy with most any oil except the friction modified stuff.
