Hmmmmmmmm
Interesting question, and I am wondering if your installation may be different from mine? I have a 1980 model. The engine mounts themselves are lag bolted to a substantial length of wood on either side of the pan. These, in turn, have horizontal fasteners (probably lag bolts, too) that go into the vertical sides of the pan. By fiberglass shoulders, do you mean the sides of the pan? Or is there no wood visible in your boat? My engine is the original, a 2QM15 Yanmar, so if yours is different or if your boat has been repowered, I wonder if something has been changed. In my boat, the mount with the most vibration has always been port side forward, with starboard side forward a second. The lags on the port side forward did eventually come loose, but a much longer lag did the trick.I can't remember, since it has been awhile, but I don't think I increased anthing other than the length. Interestingly, the mounts themselves are not the standard Yanmar, which give much better vibration dampening. I have theorized that the extremely tight fit on the starboard side of the engine dictated that the mounts be less flexible than normal, to keep the engine from bumping into the right side of the engine compartment. It was not a cost saving, since the Yanmar mounts are cheaper.
