Two boat owner.......lots!
I just bought my second O'Day 25. I now own a 78 O'Day 25 "EXHIBIT "A" and a 79 O'Day 25 "Continuance".I pulled the 79 "CONTINUANCE" down the driveway Friday night. My plans are to remove everything connected to the deck, and the thru-hulls,goungens, ports, etc.If it comes off ...it will be taken off. Everything will be rebedded (this time I am going to use 4200, Last time Life caulk)and reinstalled.The accessible wiring will be removed and rewired. A Guest battery charger, Horizon speed/depth/log, misc. convenience 12 volt outlets and two new cabin lights (one in the quarter berth and one in the vee berth)All the through hulls will be changed to bronze and each will be install with a ball valve and hoses.The table will be removed and a new one made. The companion-way will get new mahogany boards and a shelf will be built on the bulkhead between the cabin and and the head. The table will attached to that.The gel coat will under go transformation with either polyglow or Island Girl products. This is a hard decision....Then the little things. Rod holders for fishing, Cup holders in the cockpit, Bimini, Rain tarp, rebuild the whale pump at the galley and the head, two CPU fans that draw about .2 amps ( one in the vee berth and one in the quarter berth.)Install roller furling and have Tom Bell of Washington PA. make a genoa to fit it.Have the main sail cleaned and misc. repairs done at Sailcare of Ford City, Pa. If this sounds like alot, this is the second time , EXHIBIT"A" got all this 2 years ago.Got to get to work.....r.w.landau
