Another thing--
In addition to what I wrote above, be wary of aluminum corrosion behind the plate on this sheave pin. My patented, frugal trick is to lay white electrical tape on the face of anything stainless before installing it to the spar-- you can trim it with a (sharp) X-Acto knife and make a very good gasket to insulate against bimetallic corrosion. Lithium lube doesn't hold up in this sort of application; and why buy anything more than a $1.99 roll of tape to do this equally well?
