Whatizit?
mike43067
Can anyone tell me the purpose of the wood slats in the cockpit of the 23. I'm talking about the ones covering the indentions in the seats near the cabin hatch. Are they grab rails, hiking braces or just decoration?
Mark Sanford
Cup Holders??
The only use for these slats that I can find is as a cup holder. Note that you must use a soft plastic type which you can bend slightly and jam it in. They also don't work very well in heavy seas!
Davor Kusec
wood slats
I have a '86 h23 and have also wondered what these nice teak slats are for. s.v. "Miss Brandy"
C
Chris
not sure but.....
I'm not sure, but I think they are meant to wedge your feet in as the boat heels..... I'm not sure if you'd want to do that... They don't work as hand holds, (too low)..... I don't think they are just decoration, I think Hunter envisioned SOME use for that..... As long as we're asking questions, I assume that the aluminum strip covered with wood on top of the cabin roof are handholds? But they SUCK as handholds!!! They are uncomfortable and not very strong (they flex easily) If you step on them they REALLY flex. Why didn't Hunter use normal handholds like everyone else? Take Care! Chris
G
Geoff Kloster
Hunter doesn't know
Jim Bohart said (with tongue in cheek) they were for hiking out. That being an obvious impossibility, I assume Hunter has no idea what they put these things in for. They look nice? We've used ours for hanging wet towels, hanging sail ties, stuffig styrofoam cups in, haning the main sheet on at day's end, and perhaps more. This year we took one off. It clearly is an improvement when heeling. The angled indentations are very a comfortable foot rest/support when at 20 degrees. When heeled the other way one has to stick his/her foot under the board or consider breaking it. Very hard on toes.
mike43067
thanks geoff
I was wondering what Hunter would say......I emailed them but no response yet........you've answered my question. They are nice decoration.
steve d.
Wood slats
They come in handy for holding water-gatorade bottles or jib sheet tails, but I lost my footing while heeled 35 degrees once and put my foot right through one, scratching my ankle a bit. Teak strips cost me over $14 for 4 feet. I'm more careful now! They do look pretty after a little varnish.
Jon Bastien
They're the perfect size...
... For holding the feet of the sawhorse I use to support my mast while trailering. The weight of the sawhorse/mast is borne by the fiberglass of the cockpit seats, but the slats help keep it from moving side to side or front-to-back. (I know this isn't the original method for transporting the mast- the manufacturer's mast crutch wasn't with the boat when I purchased it. I had to get creative.) --Jon Bastien H23 '2 Sheets to the Wind' Key West, FL
