This fitting on my Yanmar, just downstream from the RW pump, has a NPT thread but has to end up oriented with the nipples exactly straight up to remain clear of the alternator.
It feels like it will want to stop turning just as the nipples are pointed straight towards the alternator. It's the usual NPT (or whatever metric equivalent is used in civilization) conundrum, can I make another turn without breaking it or stripping it? Aside from the normal fear of breaking a probably irreplaceable part or stripping the threads in my engine block, there is the issue that I probably can't exert enough force to make another 3/4 turn without pulling the engine out of the boat.
I've been living with it slightly loose with lots of pipe dope on it and it only leaks a tiny bit. The big pain is every time I need to change the zinc which always ends up tighter than the fitting. Working with two wrenches in the confined space isn't pretty.
So, what do you suggest? All I can think of is a pipe dope that will set up very hard.
Speaking of pipe dope, is Master Plumber TFE suitable for salt water use?
