What would you do if this happened?
Other Catalina 30 Tucson, AZ
My good friend Stu J is always reading my mind!! It isn't easy to think up topics that lead to a discussion and my plan was to use the mast failure topic as a segway into this topic but Stu J jumped the gun on me.
Here's the set up --- you have to visualize you're on your boat RIGHT now sailing along closehauled in 10 knots of wind enjoying a "tinney" and your beautiful partner. Life is good-- right. Got the picture??
Suddenly the SHROUD breaks!!!! What is the first thing you do INSTANTLY and give the reason why???? Remember you've only seconds to decide what to do.
Another scenario -- same sailing situation but this time the FORESTAY fails. What's the first thing you do INSTANTLY and give a reason why???
Last scenario --- same sailing scenario but this time the BACKSTAY fails. What's the first ting you do INSTANTLY and give the reason why.
Think the above situations only happens to your dock neighbor -- think again. If you can't answer these three questions immediatley then do your homework or read the comments from guys that know what to do in each situation and store it in your memory.
When I bought my C30 I knew the deck harware had problems because I could see the cracks. The first thing I did was have a local rigger check the whole situation. What I couldn't see at the top of the mast was worse than what I could see at deck level. This boat was a accident waiting to happen and the previous owner had it in charter!!!! How many mates chartering boats would know what to do in the above situations. The answer is a precious few!!
Stu, I'd never make a good pilot. I'd always be looking for a landing field!!!!
Jan 30, 2012
1,150
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
I will have a lash. Helm thus to turn the broken shroud to the leeward side - the side of the rig that is not in tension. Down the canvass. Rig up something to make things stable. Install replacement?
Jun 16, 2011
173
Catalina 350 Rock hall
Shroud- tack to put on leeward drop sails
Forestay- turn and run off downwind drop lower jib secure jib halyard to stabilize
Backstay- luff up head to wind lower sails secure main halyard or topping lift to stabilize
I have a b&r rig so Forestay would be worst case for us
Joe
Jun 1, 2004
8,259
Immediately put the damage to leeward...
Sep 12, 2010
66
S2 8.0c Ninnescah Sailing Association
I'm fairly inexperienced and have thought about this a lot last year. This is what I had in my mind I would do... I would turn into the wind and drop the sails in all scenarios.
Forestay - use the jib halyard as a temporary forestay.
Backstay - use the main halyard as a temporary backstay.
Shroud - use either the jib or main halyards at a temporary stay.
My lowers are fore and aft of the mains so hopefully those would buy me some time if the fore and back stays broke.
I look forward to the responses and advice...
Thanks.
Doug
timvg
May 10, 2004
276
Hunter 40.5 Long Beach, CA
Suddenly the SHROUD breaks!!!! What is the first thing you do INSTANTLY and give the reason why???? Remember you've only seconds to decide what to do:
Tack immediately onto the opposite tack. This takes the pressure off of the broken shroud.
Immediiately run down wind. This takes the pressure off of the forestay.
Immediately turn the boat into the wind. This takes the pressure off of the backstay.
Mar 8, 2011
296
Ranger 33 Norfolk
If there is something you can do when a shroud breaks, does that mean the mast doesn't instantly fold over at the spreaders?
Joe
Jun 1, 2004
8,259
Yes....... turn the boat immediately..... if it's a wire failure it won't pop clean, it will most likely begin unravelling... failing strand by strand.... A fitting failure, such as the turnbuckle, may be more instantaneous and you won't have as much time....
In any event... shifting the load over to the good side by turning the boat asap may give you time to figure out how to save the rig.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
You've all got it wrong. The FIRST thing I'd do is let off an F-Bomb, then tack/turn down wind/turn into the wind. :D
Nov 28, 2009
495
Catalina 30 St. Croix
I've had all 3 happen to me through out my cruising and racing years. The only time I lost the deck stepped mast was in my 1987 Hunter Legend 35. In that case the compression post support above the keel collapsed and the deck curved downward enough to loosen up the whole rig while going to windward in 15 k apparent. It folded in the middle and went over the side. Cut the whole thing off and let it sink. Started the engine and called the insurance company to get a new improved rig.
Jun 3, 2004
1,863
Macgregor 25 So. Cal.
I guess there is one advantage to trailor sailing, you can check the rig everytime youu go out.
As to the what if's the first thing is to remove the load either by changing course or releasing the sheets or both.
I carry 4 cable clamps and motorcycle rachette tie downs for emergency repairs.
I received a personal email today indicating I'm scaring the crap out of newbies with some of these scenarios!! How scared with this person be if one of the events actually happened and he was not prepared to deal with it? Being unprepared can actually get someone killed.
Here's why I do what I do. My wife and I have grown children who refer to us as "Mr. and Mrs. NO". You should hear some of the ridiculous things they they come up with -- maybe your children are the same way. Anyway, some of the things they do defy logic and good common sense. A 6th grade student would think they were crazy ideas!! We are not negative and go against ideas just to be obstinate. Our goal as parents is "to light a fire of ideas" ----- same thing here on the sail trim forum!!!
Jan 30, 2012
1,150
Yes - very good point. Meanwhile, how did the answers to the original question measure up?
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Hi Don,
I like having a "Plan B" if there is a situation developing. It would be far worse having something go wrong and not having a clue what to do. Knowing how to start it, stop it, and what makes it go are the basics. How to take care of it from then on is the real education. I enjoy the mental exercise, keep 'em coming.
All U Get
Nov 19, 2011
1,489
MacGregor 26S Hampton, VA
We should ask the guy on the Viagra commercial. When his main sheet let loose, he held the loaded main/ boom with one hand while he calmly used his belt until he could grab another shackle.
Apr 5, 2010
565
Catalina 27- 1984 Grapevine
Maybe I'm a big chicken but I carry bolt cutters now. In a worse case scenario I'm cutting it all loose and will lash it to the side if possible. I had a C22 forestay break loose and come back on me, and I really wanted it somewhere else. And no Don, it's not a bad question at all, just one I figured out while covered in sheet, boom, wires, halyards, etc in a 30kt wind. I remembered thinking " I wish I had some boltcutters" :doh:
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
but bolt cutters won't cut stainless cable .. at least I don't think they would. you would have to cut turnbuckles I guess.
Feb 20, 2011
8,062
Where did the forestay fail? And please, don't say "In Grapevine"!
Apr 5, 2010
565
fitting at top of mast was missing when I sorted out the pieces. And yes, my bolt cutters will cut stainless, quite well
