Some Hard Choices
This scenario gives very little information, but the information it does give is chilling:1. Unfamiliar boat/equipment.2. Moderate/fresh breeze.3. You're alone.4. MOB is injured.Some responders are still not reading the situation carefully as it was given. You're not on YOUR boat, with all the equipment YOU so wisely bought: you're on SOMEONE ELSE'S boat, one with which you may not be familiar, and this is really the wicked twist in this situation: you're at a big disadvantage, because you probably don't know how his boat behaves in 15kts of wind, or the peculiarities of his running rigging. Gary didn't say you'd ever been out on this boat before, so you have to assume that you haven't.There are also many other assumptions being made here that makes it easier to give answers, when those conditions may not be true at all, and some of us are apparently super-men, which has been pointed out. At best, because of the limitations you're working under, this is going to be slow, and probably clumsy; possibly tragic. Some things are simply out of our control.If we stay within the limitations of the scenario as given, and allow for all the things we don't know, any proffered solution will have to be given in general terms. So, generally:1. I'd throw something first. He went over the leeward side, and you heard him hit the boat (freak swell to do that, but that's what happened), so you have to presume that he's injured in some way. Getting floatation to him, esp. if he dislocated a shoulder or took a clock-cleaning knock to the head, is paramount. By the time you get to the stern rail to grab whatever-he-has-hanging-there and control your adrenaline-shaky fingers enough to dislodge it (Damm it: only a coiled line with a monkey's fist: I never should have given him that Book of Knots for Christmas! Grab a cushion, fast!) he should be visible at/near the stern, if indeed he is/has surfaced at all. If you don't see him, you still want to put out a marker as close to the MOB as possible. Two reasons to throw first.I can't assume there is a GPS, or if there is one, that I know which buttons to hit to trip the MOB function on his unit. If I'm unfamiliar w/ his equip., I don't think I'd spend any time trying to figure it out, unless it's pedestal mounted and I just happened to see a big red MOB button. I'd take a tenth of a second to jab at it, then get on to:2. Checking the forward motion of the boat. I don't have any other crew, so unless I'd already practiced an awful lot (and I admit I, for one, haven't: any other honest posters out there?), I'd skip Figure Eights or Quick-Stops, and just heave-to. The advantage of heaving-to alone is three-fold: A) your hove-to vessel has a good chance of winding up directly to weather of the MOB, or nearly so, B) you'll stay closer to the MOB: 5 kts = 8.4 ft./sec. If I can get the boat stopped in ten seconds, I'm only about 30yds. away, and C) it keeps the body of the boat and sails out of your line of sight, and lets you act as spotter and boat handler simultaneously. You will then begin to come back down toward your marker, approximately. You will have a minute to3. Spot or re-confirm a visual on the MOB. If you can see him, you're clear to4. Start the engine. On a 30-footer, I'm assuming an inboard diesel, still warm from steaming out.If you do not see your MOB, or did not at least see him clear the boat and know that he is well away, YOU CANNOT START THE ENGINE: there is a possibility that he's hung up on the prop/rudder. He's already dead at this point, but you don't want to be responsible for the gruesome consequences of touching that starter button and shifting into gear.4. Of course you've been keeping an eye on you MOB, As you drift down hove-to, you will have a few seconds to try to spot him and assess his condition. Both arms around the float: probably lucid and not injured much; one arm around the float: likely an injured arm and/or concussed/semi-conscious; float only: of course you scan the area immediately, but his soul may have shed its mortal coil already.5. As you near your float/MOB, blow both the the genoa sheet and main sheet, flogging be damned: the sail loft can repair that later. This will allow the hull to be driven by the engine. You will likely remain approx. beam-to as you drift down the remaining distance, and will need to power either in reverse or forward to bring your stern close to your MOB without running him under.6. Drop the swim ladder (sorry, sugar-scoop, walk-through transom people; without info. to the contrary, we have to assume a traditional design. Remember: NOT YOUR BOAT).7. He's at your stern. Communicate to assess injuries and/or his level of orientation. Does he respond to his own name? Is his head up? Can he communicate clearly? This evaluation will determine a lot of what happens next.The wind speed is 15-17 kts, which is at the border of Beaufort Scale 4/5, moderate breeze/fresh breeze, with wave height of about 3 feet, max (not 5 feet, as was suggested). Beam on, it's a little rolly, but not too bad for a 30-footer of 10,000–14,000lb. You can still get things done with one hand for the boat. Depending on his ability to assist in his own rescue, from here the preferred actions, IMO, would be:8.Shut off the engine to preclude complications from exhaust as you work off the stern.9. Extend a boathook or similar reaching device that he can grab to get him to the ladder and assist as he re-boards under his own power (he's able-bodied and clear-headed).If he's unable to grasp or hold onto the boathook, snag some clothing & gently draw him to the ladder. If he's at all disoriented or even just moderately injured, you will very likely not be able to do much more than this by yourself, and must content yourself with stabilizing him in the water until help arrives.10. Now is the time to get a line around him (the horseshoe buoy tether? Mainsheet tail? Sail ties? Whatever is at hand), secure extra flotation to him, secure him loosely to the ladder so he's not buried under passing seas, with some protection (fender, cockpit cushion, whatever) between him and the transom if the swell makes the hull a danger to him and/or he's not able to keep himself safe.11. Issue a PAN-PAN on ch. 16. Chances are the current situation is not immediately life-threatening, and you can wait the 15 minutes to get medically-trained manpower with sophisticated equipment. He's heavier than you: you will not be able to lift him straight up into the cockpit; and not only is attempting to rig a boom-and-sling not necessary, it will likely exacerbate his injuries and add trauma, which is spelled S-H-O-C-K. He's more stable in the water with you talking to him to keep him calm/lucid and slipping away briefly to answer CG calls on the VHF. Your flogging sails will make you stand out from the weekend crowd, so tell them about that. Hypothermia is not a threat conidering the time window you're operating in. No need for off-shore heroics when you're a thousand yards outside the breakwater. (Don't move an injured person unless you need to).12. Attend to your friend to keep his face/head as clear from the water as is comfortable and practical under the circumstances, and keep a lookout for other traffic you may have to wave off. Your vessel is now not under command, and you don't want powerboaters coming close and throwing big wakes your way that could bury your MOB's head under. You might have to provide artificial respiration by lashing him in a bit tigher and hanging over the tranom if the swell allows, or as a very last resort, donning flotation and climbing down the ladder to him. The CG will just have to find you on its own, then.13. Thank God for the creation of the modern Coast Guard in 1913 by the combination of the LIfe-Saving Service and the Revenue Cutter Service.*** *** ***Whoever cited reach/throw/go is correct: only if I got the boat close and stabilized (drifting), would I consider going in after a struggling victim, and that's only after reaching/throwing attempts were ineffective and the MOB could not keep his face above the water with minimum distress. Even then, I'd bring flotation: a PFD if one were handy, or a nice long cockpit cushion or two, or a medium or large fender. A hastily emptied ice chest with a line run through the handles is awkward, but can serve in a pinch. But I'm a former lifeguard, and know how to keep a panicked and flailing victim from dragging me under. For most of us, once he's under the surface and out of the reach of flotation, diving after him is likely to result in a double-drowning. You might get lucky with a sinking thrown line (maybe that monkey's fist saved his life after all). And Leaving the boat before you're sure it's under control could result in someone else's death as it causes untold havoc. Sometimes discretion is the better part of valor. Sadly, alone, you options are limited.
