Ball valve recal
Abe: Called Hunter's customer service Wednesday last, and talked to AL. He says that Hunter will pay for haulout at rate of $10 per foot. He says that Hunter found just one valve in the listed Hull ID numbers which failed to operate as required. He said Hunter disassembled it, and found it to be corroded, and in discussions with the Coast Guard agreed to a valve recall. Hunter does not appear to see the valve replacements as a critical job for accomplishment right now (unless you have one that doesn't work now.) Main threat appears to exist if a hose leaks or breaks, and you need to shut out sea water from the boat but the valve is stuck open. We think the best defense in the short run (pending valve replacement) is to shut all valves every time you dock, and open them next time you get U/W. Weekly cycling is probably the best defense for protection against any MFGRS' valves corroding and sticking open. I was not on their list for the Hunter's valve notification mailing (2005 H-306, bought in Sept 2004). But my son saw it on Hunter's web site under "Notifications". Incidently although Hunter says they expanded the range of suspect Hull ID #'s just to be safe, our boat number was just outside that range. But we know for a fact that we have the suspect valves on board. Every Hunter owner should 1) Check the notifications on the Hunter web site. and 2) Don't trust the stated range of hull numbers. Check your boat personally. You may have an experience like ours. Watch whoever does the replacement job. They must use new (two of them) stainless hose clamps on the new valves' hose connections.
