Mark Cooper
Yesterday was a brilliant day on the lake... weather in the nineties, but a 20- 25 knot wind kept it cool. We sailed under jib alone and were achieving speeds of 4.5 - 5.5 knots. Then, in the middle of the lake, we watched in disbelief as the jib suddenly launched itself to port- the leeward side- and disappeared into the water. Seconds later, the mast fell down onto the deck. Luckily, we were on the high side of the boat and so no one got hit. Rescueing the jib- still attached to the entire roller furling assembly, I managed roll it back up and pull it back aboard where I discovered the pin attaching the furling to the bow had pulled free, but was still in one eye. So, after a few minutes of heavy breathing, we managed to put everything back together and were pleased to find we sustained no damage.However, I am greatly concerned about what caused this. I'm thinking that the problem may have been the clevis pin I was using, which was of the speed clip variety. Somehow, during this or another sail, it'd worked its way back to the point that it could no longer hold itself in the other eye of the support and pulled free. I'm thinking about using a 1/4 inch stainless bolt to attached it more securely and permanently. Does this sound feasible? Does it open me up for more problems that I can't foresee?Greg Emerson, if you're around, do you have any thoughts? Has this happened or nearly happened to anyone else?
