I had some reply from my other post that were good, but I read somewhere that some people always had problems with their stern bearing unit (stuffing box) on their combi set up with variable prop and Volvo md6a.
I pulled the Vega from the water for a few reasons, one being the stern bearing unit (stuffing box) the forward seal ring 840252 leaks bad every time I run the motor, have to grease the stern bearing unit after every run, or I better have a good bilge pump with unlimited electric.
Motor seems good still, and I just want not to worry about getting my batteries flooded or worst case Sink, so what would you do or have done other than replacing the motor set up!
Should I take out the shaft and just install new stern bearing bushing and seal rings and then repack with special grease and this will most likely fix having to grease after every motor run,
Should I install New prop and new shaft and new transmission, and modern stuffing box, if I can do this what type of set up do you know about, and do you know some dealer with experience with this who could sell me the parts?
Or is there a modern stuffing box that will work with my set up, if so what type size make model?
Lost on what to do.
Stephan
Lost on what to do.
Stephan
