Started my first full summer with my C22 off right this weekend. Got it out of inside winter storage all dry and headed to Lake Michigan on Friday with my teenage sons. Launched and sat in a slip for nearly two hours having lunch and chilling...bone dry in all the port and starboard bilge areas. Once under way with no heel we noticed the forward port dinette seat bilge area was getting wet just under the keel lockdown...the bolt has grease on it and was dry itself....after a two hour sale I pumped out 1 gallon from that area. Suggestions on what to check please. I was looking along the keel tunnel up near the lock down bolt...the fiberglass looks very unfinished and corse cloth and damp and so I wondered if PO replaced lockdown and didn't use enough resin to seal things up right? Water could be splashing up higher in the keel tunnel when moving vs when sitting in the water was my thought. Really don't want to remove keel to check if there is another way to investigate and repair. Thanks
