What Thru-Hull?
53
- - Nassau, Bahamas
I am about to replace all the thru-hulls in my 30ft Hunter, and as the old ones have coroded badly, I was considering using marelon thru-hulls has anyone had experiences with marelon or similar thru-hulls breaking? I just want to have ones where I do not have to worry about electrolysis and not bother about corrosion. Thanks
Jun 4, 2004
629
Sailboat - 48N x 89W
Forespar
Marelon Thru-Hulls & Seacocks have served me well over 20 years use. Gord
Mar 1, 2005
220
Hunter 34 North East, MD
Lubrication
I put Marelon ball valves in my previous boat. As long as you lubricate the ball periodically as recommended, there should be no problem. If you don't you risk breaking the lever off from trying to force a stuck ball open or closed. This is the usual breakage issue.
Jun 16, 2004
130
Catalina 30 Mk1 Horseshoe Bay, BC
I used Buck Algonquin valves
...they have a grounding screw. I didn't trust marelon, however they seem quite strong. See my website link for details. -Rob
