What the Heck is this?
JamesG161
Feb 14, 2014
8,019
Hunter 430 Waveland, MS
It is an adapter that screws to a quart of gear lube. The yellow and black sections twist to turn the flow off/on. This way you can put the hose in the filler hole and then open the flow of lube.
Where I found it was near the genset and the inside of the tubing was not oily but looked like dries salt water.
On yours, do you have a "quick disconnect" on left/white piece?
Jim...
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
No disconnect on mine. Yours was added. The white end screws onto a bottle. The twist valve works pretty well, so it could be used for just about any use where you need to turn on/off the flow of a fluid.
JerryA
Sep 15, 2013
708
Catalina 270 Baltimore
Maybe it is a backflow preventer. Something that allows water to flow one way amd not the other. That may account for the arrow. I had to use one for my irrigation at a previous house I used to reside in.
JamesG161
Feb 14, 2014
8,019
Well avoiding all the storms on the weekends, I finally got to search and the boat. I found only a back up spare.:confused:
he assembled a do-hicky.
The do-hicky is the twist open/shut valve as many noted.
But...
I never found the gozinta black end mating piece. The dangley tubie on the yellow Wachamycallit showed no oily stuff.
I owe the following a plethora of Greek...
the craft beer
@Gunni , @centerline , @JerryA , @woodster :liar: BTW...
The PO cross threaded the gozinta in the white thingy and therefore he needed a spare.:doh:
Thanks all...
Jim...
PS: @Gunni gets the innovation prize for....
your wash-down pump intake it would provide the ability to use your wash-down as a bilge pump.
:yeah:
