I noticed a hole / crack in my pop-top yesterday. Right where the sliding companion way hatch would rest when in it's fully closed position. Not sure how it got there -- sometime over the winter, though the boat was covered (at least that's what I assume). Maybe it was there longer than I thought and water got in and froze.
I'd like to remove the sliding hatch portion of the pop-top to address it now before it goes into the water. But, I cannot seem to get the wooden sliders off. I've removed the screws from the inside, but neither side budges. I really don't want to make it worse by forcing them and tearing holes in the glass. It looks like the PO might have used caulk between the deck and slider seam, but even with that removed and a reasonable application of a thin-bladed putty knife and a hammer, I can't get any movement. Then I thought about trying to encourage the hatch to slide farther forward, but that didn't work either.
Anyone have any tips for removing the wooden sliders? I have a 1972 hull. Thanks!
