Hi i have an oday 322 with a 2 cyl yanmar engine, the rubber on the radiator cap is worn and i want to replace it, does anyone know how many pounds pressure cap i should get??
I can't see any numbers on the old cap but at the store the one that was the same shape as mine and had the same size lugs on it said 7.5lbs but the spring on it was a lot less spring tension than mine, but the one that felt like the same spring tension Said 14 lbs but the actual cap has different size connector lugs on it, anyone know the correct cap pressure for this engine ?
