I am adding a MRBF Temrinal fuse block to my electrical system.
My house current draw is approximately 20 amps and will go down as I switch over to LEDs.
For that I plan to wire for 40 amps and use a 40 amp MRBF fuse. 6' run of #12 or #10 wire from battery to breaker panel.
Does anyone have an idea of the approximate current draw of a 9.9HP Yamaha Outboard when starting?
Do I need to go to a higher amp fuse or add a double fuse terminal and fuse the outboard seperately?
Thanks
Thanks
