What size motor?
Dug22
Jan 29, 2019
67
Catalina 22 Vincent Alabama, BSC
What size motor is suggested for the Cat 22? What is the preferred HP?
It all depends on where you are and how you use your boat. On SF Bay we had a 7.5 hp Merc 2 stroke in the 80s. If you're on a lake and use it just to get into and out of your slip, a much smaller one would do just fine. Anything bigger than a 7.5 2 stroke IN WEIGHT may be pushing the limit of your outboard bracket, and would not do good things to your transom.
Dug22
Jan 29, 2019
67
I only will use it to get to and from my dock.
Jul 7, 2004
8,404
Hunter 30T Cheney, KS
Our Mac 26s had a 5HP when we bought it, but my wife wanted something bigger in case we had to fight a windstorm back to the slip. We're on a reservoir. Make sure you get a long shaft.
Jul 13, 2015
901
Catalina 22 #2552 2252 Kennewick, WA
5HP 4 stroke Honda -- all day every day against a constant 4 knot current..... can't imagine more-- seemingly too much weight or fuel consumption relative to hull speed. Sadly I haven't committed to electronics yet, I have no clue how many KN I'm making. My biggest concern is making headway against the Columbia-- no issue.
May 23, 2016
1,024
Catalina 22 #12502 BSC
default for a c22 is 6hp Tohatsu Sail Pro 20' long shaft here on the forum...picked one up recently, to replace my old 4.5 merc....
Nov 12, 2015
87
Catalina 22 Lake LBJ
I'm using a Honda 5hp 4 stroke (1984 model) and it has plenty of power for the boat.
AaronD
Aug 10, 2014
723
Catalina 22 9874 Newberg, OR / Olympia, WA
:plus:On the Tohatsu. It seems to be the universal recommendation, and I'll add mine to that chorus. Quiet, runs on less than 1/2 gallon/hour, starts every time, and it's easy to flush out (even in our slip). Ours is the 25" 'Ultra Long' shaft version, but a 20" would be fine too (we went down from a Honda 7.5, primarily to save ~30 lbs of weight and my aging back).
My understanding is that small Mercury and Nissan outboards are built by Tohatsu as well, so their 6HP models are pretty much identical. The Tohatsu 'SailPro' models add a high-thrust prop and an alternator to charge your batteries.
Oct 25, 2015
31
Catalina 22 Cave Run Lake ky
My boat had a 6HP 2 stroke for years and when I got it and I changed to a 3.5 hp 4 stroke. I seldom need that much power on the small lakes I typically sail. For rougher lakes I would go to a 4.5 to 6 hp with a long shaft to handle bigger waves. If you remove the engine, the 3.5 hp Tohatsu-Mercury long shaft is the lightest engine you can use without having to add weight to meet the 45 lb requirement to be class legal. note this engine does not have a reverse!!!!
May 24, 2004
7,131
CC 30 South Florida
Depends on the job; for a small lake a 4-6HP, for the sea a 6-8HP and for a fast moving river an 8-10HP. These suggestions are to provide power on the high side for the anticipated conditions. Be mindful that the larger engines may require an upgrade to the motor mount to be able to handle the added weight.
