Wire load
I agree with TonyK. There is no direct answer. On a 28 year old boat there could be a lot of changes. Determining the specific needs of your circuits is the best way to go, rather than a stock answer.Also, if you inspect the wires at any junction, do they look silver and shiney (tinned wires) or oxidized copper? The original wire in your boat was un-clad copper. No good in a salt water environment. If your wiring has not been replaced since new, expect bugs and plan on running new wire for all the systems. Also replace any old light sockets, mast and running lights. Scraping the bulb contacts with a pen knife just doesn't cut it after a while. Notorious for failures on older boats.Two hours work for every hour of sailing.
