Sealants
Seth, The problem you are experiencing could be caused by any type of hull cleaners you may have used on your deck, that have acids like Oxalic acid, or other chemicals that can literally eat out caulking. I found this out the hard way, myself. It ate out the caulking under my gunwale strip and I had water seeping into my forward cabin because of it. I wound up taking my gunwale strip off and caulking all the screw holes with boat caulk. 3-M makes a good Polysulfide sealant, but before you make a choice, check out the link to the site attached. Click on to "Tools and Techniques", then choose "Click here to view features." This should give you the answers that you seek on all the different type of caulking and how to apply it. At any rate, if you have used hull cleaners on your deck, you need to get away from them, and just use good old soap and water, or pay the consequences as I did.Joe
