The rubber hose that looks like it has been wrapped in tape that holds the Centerboard Pendant, where could I find a replacement? Would a Shields rubber radiator hose rated at 400 psi be suitable? When replacing this rubber hose, what sealant should I use on the lower portion that attaches to the bottom of the boat? I do have the new pendant. The one that is there now looks original to this boat. This boat was used a few years than parked, sold and parked again and everything seems original. The hose that is now there seems a bit mushy in the bend and I would assume that if it failed, we would be taking on water rather quickly. Thank you. By the way I have a 1988 O'day 25.
