What is/was this L bracket for?
SFS
Aug 18, 2015
2,101
Currently Boatless Okinawa
1983 H31. This bracket sits on the quarterberth ceiling, just forward of the rudder post/steering cable guide. It is bolted through the floor of the aft cockpit laz and the quarterberth ceiling. With old radius marks on it, I assume it was once attached to something, or was a wear plate of some kind. If it is now nonfunctional, I want to remove it and seal the holes for leak prevention.
What was it for?
Mar 13, 2011
175
Islander Freeport 41 Longmont
Looks like the rudder stop. You say it is non-functional??? The post on the top of the rudder cable wheel (can't remember the proper nautical term) while hit it and prevent the rudder from traveling too far in either direction. If you remove it you should replace it with a new one.
SFS
Aug 18, 2015
2,101
No, I said if it IS nonfunctional I would take it out. But I suspect you are both right, and I will confirm that that spindle will indeed make contact somewhere near the outer edges of the bracket. The wear marks were a red herring for me, as nothing in the current configuration makes contact on that surface of the plate.
Aug 2, 2009
651
Catalina 315 Muskegon
I'm wondering if the pin used to have a rubber bumper attached to it. That could account for the dark semi-circle mark above it. Of course, the rubber would soften the impact at full turn. Perhaps you'll find the rubber piece somewhere below?
SFS
Aug 18, 2015
2,101
Haven't seen anything like that, and it would have to be a pretty tall rubber bumper. The parallax in the picture belies the fact that the top of the pin is a couple of inches below the marks on the plate.
Love your avatar. Seal point, or chocolate?
Do you have an autopilot? Maybe for a Rudder Position Indicator.
Apex
Jun 19, 2013
1,229
C&C 30 Elk Rapids
The marks could also be part of layout work.
I like the idea of a rubber cap soften and quiet
SFS
Aug 18, 2015
2,101
Jssailem, I do have an autopilot, but we have not used it much. It does not have an RPI that I have seen.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
It looks like it might be a backing plate for something that is mounted above. Those bolts that are holding it are inserted from above. That are they holding? Maybe the pedestal or the pedestal guard?
SFS
Aug 18, 2015
2,101
Mark, they are holding nothing. The bolt heads are in the aft lazerette floor, with nothing between them and the fiberglass floor of the laz. I don't know how long the bolts are, but I am certain that there is airspace between the top side of the "ceiling" and the underside of the laz floor. My camera arrived today, so I will be spending time exploring. Will report any additional info. Right now, I'm mostly convinced it is a rudder stop, but I'm open to more ideas.
May 20, 2016
3,015
It sure looks like a rudder stop - I have a rubber hose on mine to soften hitting the stop (chunk of oak on mine).
Likes: Ron20324
