What is the recommended RPM?
Bert
Fellow Sailors, I reach my hull speed at about 2200 RPM with my 1982 Yanmar 3HM. The Yanmar specs don't provide the recommended cruising RPM and I hear that other folks run their Yanmar at 3400 to 3600 to keep their engine in shape. Does anybody know? Thanks folks.
Dec 2, 1999
15,184
80-90% of max rated RPM.
Bert: The rule of thumb is 80-90% of the max rated RPM. If you engine is rated at 3600 max, then you should be running it at 2500-2900 rpm. Hull speed is a theoretical speed. You engine should be able to turn 3600 rpms in neutral and 3400-3600 in gear. If you CANNOT, then you may be over propped and that is why you are getting hull speed at a lower RPM. If you cannot run at 2900 rpm all day without belching black smoke you have some type of problem (mixing elbow, fouled prop, dirty bottom, over-propped etc.)
David
RPM
Bert, you may want to double check the engine model. Hunter installed the very heavy duty QM series at least as late as 1981. They turn a much lower RPM than the more light duty GM and HM series. By the way is your Tanzer 10.5 a pilothouse?
Paul Akers
3HM?
My Legend 37 has a 3HM35F and the Yanmar manual rates it at 3200rpm. I beleive the 3GM30F has 3600rpm rating.
G
Guest
If your max rating is 3200....
If you max rating is 3200, then you would have a normal operating range of between 2200 - 2600 RPM's. This would indicate that Bert is doing well moving the boat at or near hull spead at 2200.
Bert
3HM Series
David, It is definitely a 3HM, as written both on the motor and in the specs, and yes, the Tanzer 10.5 is a Pilot House.
