Theory
The "theoretical maximum hull speed" is a good approximation for a sailing vessel with a "slippery" displacement hull form. It isn't a wall that cannot be exceeded, however.Since it's based upon the propulsion energy supplied by sails (or an auxiliary engine), the limit factor dominating will be when the standing wave crest-to-crest created by your forward motion is about equal to your waterline length.To "punch through" that standing wave, much more propulsion energy is needed. That energy can come from very high winds and/or wave action. There are many cases when boats caught in storms are surfing along in excess of hull speed under bare poles! (hence using drogues to slow things down).This max hull speed phenomena is analogeous to the "sound barrier" for an aircraft. Lot's of extra energy needed (and a different hull shape) to punch through.Power boats with semi-displacement hulls and lots of horsepower under the hood can get into a planing mode fairly quickly. Ditto for inflatable dinghies -- flat bottom, low weight, and a big engine. I suppose if you strapped a few 275 HP outboards on the tail of your C30, you might get into a planing mode, too. Might alter your trim a tad though ...
