More on rig taxonomy
I believe it's the case that any rig where the jibstay is below the masthead will be "fractional", even the B&R design mentioned. A significant characteristic of a masthead rig is that the forestay also supports the jib, while with fractional rigs there may be a "babystay" or short shroud running from the lower front of the mast to the foredeck instead of a long forestay at the bow.Cutter-rigged sloops (2 jibs) are not really "fractional" because the aft jib is considered, in the old windjammer terminology, a staysail (an auxiliary jib rather than the primary).The "fractional" rig probably got wiped out by the IOR (International Ocean Racing) rule introduced in the 80's, which encouraged large jibs and small mains, a trend which us owners of used boats from those eras suffer with.The predecessor of the swept-spreader B&R idea were the running stays on gaff-rigged boats--the gaff (upper) boom made a backstay impossible so moveable stays were rigged to the side decks, on tracks like our genoa lead tracks today, and had to be moved before coming about (big trouble to forget that one!)When the mast runs all the way to the keel it is "keel-stepped". When it is balanced on the coachroof it is "deck-stepped". The deck-stepped mast is always supported underneath by a "compression post", often a pole supporting the salon table that runs to the keel.Tereza's description of how these rigs work is right on the money and will save years of confusion--memorize it!
