What is the best propeller?
L
Les Blues
I have a 1975 Catalina powerered by an Atomic 4. My shaft is 1" and the propeller is a three bladed 12" 6. As I have just found a crack in it, I was wondering if I should replace it with one of the same dimensions or whether there are better options.
jchealey
proper prop
my cat 30 also has the a-4 with a 2 blade prop. it is more power than the boat really needs. the prop is a 12inch 7degree pitch (12 by 7)
Rob R.
A few options
Try Don Moyer's site - he covers this topic very well. In short, CDI and a few other companies make props specifically matched to the Atomic four. You can go with a three blade or two blade, and the CDI two blade design has received some very good reviews. Pitch and size are the determining factors. www.moyermarine.com Please post your findings back here, as I and other A-4 owners are always curious. Best Regards, Rob
