What is the best bottom paint for Hunter 240 located in Florida, Tampa Bay.
Chern
Dec 19, 2017
22
Hunter Hunter 240 Sidney
Long lasting, less cleaning. Is the most expensive is the best paint? Or any budget paints can work pretty good? Please give me advice.
May 1, 2011
5,017
Pearson 37 Lusby MD
My experience has been that the more you spend, the better the bottom paint works.
7,435
Alden 50 Sarasota, Florida
It depends where you are, I.e., the water conditions where your boat is. For example, the most effective anti-fouling here in Sarasota may not be effective in Tampa Bay for a number of reasons.
Ask the locals what they use, not people here.
capta
Jun 4, 2009
4,935
In my experience, in the tropics, the cheapest paint I can buy does nearly as bad a job at keeping our bottom antifouled, as any other. After a few months, you or somebody is going to have to clean the bottom on a regular basis.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Others have provided good advise.............just to add check with your marina boat neighbors and bottom cleaning diver for their recommendation.
Jan 4, 2006
7,264
Exactly.
I had been using Micron CSC for years and repainting every two years. Acceptable bottom condition. The reason for every two years was that my indicator coat (bottom layer coat, black) showed through every two years.
An employee at West Marine suggested I try West Marine CPP Plus which is just under 50% of the cost of micron CSC.
The first two coats were applied in 2013 and the indicator coat showed through in 2019. Not bad for seven years. Same kind of mileage as before.
Good for me in my waters ...................... maybe not so good in your waters.
8,492
Hunter 30T Cheney, KS
Are you trailering your 240 to the water or keeping it in a slip? Maybe you don't need bottom paint at all. Just powerwash each time you haul it out.
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
For questions like that I ask the folks at the local boat yard. Go to their store to see what they are selling, etc. Also, bottom painting w/anti-fouling paint is a multi-step process if done correctly. The paint itself is only a part of the cost. Good preparation of the bottom is typically the step that leads to the best outcome, especially in relation to its condition before painting.
7,435
Thank you all. By the way how much paint do I need?
Buy 1 gallon of what the locals suggest is effective where you are. You’ll have half left over for next year and you can be sure the price isn’t going down anytime soon.
