Does anyone know the angle of the transom on the 25?I need a new (lifting "auxiliary") motor mount for my 9.9 outboard 4 stroke Yamaha, and the current set up has never worked properly.Unless anyone has a better suggestion, I am going to have to spring for a new motor mount, but I want to make sure the mount we buy will adjust enough to fit the back of the Seidelmann 25.Does anyone have a better solution?Currently, ours is setup with a metal shaft that runs straight through the transom and is held in by a mass of fiberglass (under the cockpit, in the lazerette). That has a flat mount welded on, "t" shaped. then a spring loaded rising mount is attached to that. And finally the engine on that.It has developed a lot of dangerous flex, reversing is scary (the motor lifts 4-5" out of the water), and it doesn't lift the prop fully out of the water either.Thanks,BillDariamoree@moreephoto.com
