What is it
scolil
Jan 5, 2007
64
Macgregor Venture 25 Any puddle with ripples, Utah
I recieved this boat from my father. It has no hull ID. It is 26ft LOA. The gentleman who sold it to my father said it was a 1969 MacGregor 26. It needs work, but before asking questions about fixing things I wanted to know what to call it. It has a swing keel that I believe is made of lead. Thanks for your help!
Ross
Jun 15, 2004
14,693
I would call it the Nancy S.
But it is your boat so you get to choose. Or you could just call it free. ;D
May 31, 2004
858
Catalina 28 Branford
Hull id #
Look in the upper right corner of the outside of the transom. There should be a series of letters and numbers impressed into the hull. This is the hull id number. Copy it down. Go to the website below and decipher the manufacturer, year built and other fun and useless information.
Ross
Jun 15, 2004
14,693
Mike ,that only works on boats built post 1973
prior to that it was on the makers name plate inside the boat somewhere. It (the name and other ID) might be on some old registration papers.
Rick
Reply to: what is it?
Scolil- This looks like a Balboa 20 to me. The mast has no spreaders that I can see. Check the length bow to stern. The Balboa I had has the ID# on the Starboard side of the transom where the deck mounts to the hull. Look close, it took me a while to locate mine. Rick
May 11, 2004
149
Pearson 303 Lake Charlevoix
Maybe a Venture 21?
I know you said it was 26', so I may be way off, but it sure looks like a Venture 21. http://www.sailingtexas.com/cboats99venture21.html http://www.ne-ts.com/mac/bb/76brop3.html Dave
C
Chris
It has a state reg #
so it should have a name and ID on the registration document. Failing that, DMV should be able to pull up the info from the reg number.
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Looks Like a Venture 21
but it should have spreaders if it is. Rick could be right since he had one. I have only known people who have had Venture 21's, but that was years ago. You might post on this site to see if anyone there knows.
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
Venture 26D maybe?
It looks like my V-21 except the cabin is sloped and mine isn't. I see the shrouds but not the spreaders but that could be because of the photo angle.
A
Anchor Down
Visual Comparison
That is not a 26-ft boat. Here's a pic of a Venture 21 from yachtworld.com
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
17
My Brother has Venture 17 which looks the same. Only way to know for sure is with a tape measure. The only thing that this boat sems to have is some sort of a traveler track for the jib. His doesn't.
Feb 15, 2007
47
Macgregor 26D Gautier
Mac25
Heavy swing keel sounds like a Macgregor 25. The keel is iron instead on lead, with a trailor type winch to raise it. Post the picture on Macgregor owners site and you'll find out for sure, and find about a thousand fellow owners.
Apr 25, 2005
410
Macgregor Venture 25 My Backyard
It looks like a MAC, but not a 25
A 25 would have 2 windows on each side, and also it would have the lifelines that go to the cockpit. It appears as though it doesn't have a poptop either, which makes me think that it is either smaller than a 25 or not a Macgreggor at all. I also say post this on the MAc sight to see what you get. Good luck.
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Venture
One of the things that struck me about the Venture was the stern Main "Traveler" setup. It isn't really atreveler so much as a traingle shaped attachment for the lines. I'm not sure that they used these on other boats but this photo has that setup. I would look for some form of nameplate. Stern or inside of the cockpit stern. Another thing about the Venture was that it had one combination scupper that also was for the steel cable that lifts the keel. The winch was on a board above the hole. They may have done different on a larger boat than the 17.
May 5, 2006
1,140
Bilbo
The scupper keel cable hole combo is the same for my 1976 V-21 and so is the triangle sheeting system, which I'm about to replace.
May 4, 2005
4,062
Venture 24 or 25
1969 boats were 'venture' later renamed macgregor. in really good shape its worth maybe 4-5k. (more if lots of extras). the keel pivot bolt is a problem area, and a pita to fix... typically the hull id will be inside the boat, towards the rear bulkhead, with 'drilled numbers' (swiss cheese) (the later M25's had an innerliner) go to macgregor-boats.com on left are manuals...
