Night vs Day
Ahoy By,The Capri 25 -- like almost all of the Capri line, is designed primarily for racing as opposed to the Cat 25 which is a small cruiser. I say "almost" because the Capri 26 is said to be a racer/cruiser -- a bit of a mix between the two boats.The Capri 25 is much wider -- probably at least a foot beamier than the Cat. and has some wide walk ways topsides for crew to move about on. The cockpit is larger also -- again to hold crew.This is all at the expense below decks....it's pretty spartan down there...you don't have nearly the room that you do in the Cat.Brad
