Proper use limits liability
I teach sailing primarily on inland waterways. I carry a blow-horn and we always use the horn everytime we can. It not only teaches the students to understand the signals, it is a lot of fun.I have never heard other sailors use sound signals in our area, but that doesn't mean they are unnecessary. In the event of an accident, if you have used proper signals, you will reduce your liability in court.The ColRegs are a little complex and difficult to memorize, so I tell beginning students just to remember "What side of our boat do you want them to see?" Give 1 short blast for Port, 2 for Starboard. This works for all situations meeting and overtaking, Inland and International. The ColRegs use terminology something like "Give 1 short blast to indicate the intent to alter course to starboard..." but to simplify it, if you turn to starboard, they should see your port side and vice versa.The difference between Inland and International is that Inland requires a response (same signal if you agree or 5 shorts if you dissagree) but International does not require a response. Either the stand-on or the give-way vessel may initiate the signal. Basically inland waterways are relatively restricted so you are expressing your intended action to the other boat and they will agree or dissagree (if they are the giveway vessel, they should agree). Due to the large distances that you should maintain between boats in International waters, you use the same signal but you are not expressing intent, you are simply telling the other boat what you are going to do.If the other sailors look at you funny because they've never heard a signal in 20 years and have forgotten what they mean, that's OK. At least they're awake and you've covered your A$$ and had a little fun.
