Mark Wieber
(Alex)
The refridgerator on Mirage runs full time on D.C. so the charger is always on when there is shore power available. Underway, we can go for 3 to 4 days on the (three) battery bank with reasonable conservation. Then we have to run the engine. We have a manually controlled regulator that can get the charging done a little faster. Since we have owned the boat, I have checked the batteries every two months. Usually the electrolite is low and I have to add some water. Recently, while sleeping on the boat, I noticed the refridgerator compressor going on and off way more frequently than it should, I checked and the battery bank was reading 11.5 volts on both sides (even with the charger running on #3 setting) I found one bad battery, and replaced all three with Costco Marine batteries. This helped but the 1985 Adler Barber was making some scifi type noises every now and then. (the beer was still cold though) I had the local marine A/C guy come down and take a look. He found that the refridgerant was low and quoted a reasonable price to leak check and recharge the system. However, cold beer being somewhat a priority for me, I opted to replace the whole unit. It has been 4 months, the charger is on #1 setting, the battery bank is holding between 13V and 13.5V, and If any of the batteries have lost water, I can't tell at this point. My question for 'Alex' would be... what on your boat can draw power full time? Bilge pump? refridgerator, Cabin, or vent fans? etc. Probably you just have a sulfated battery or one with a bad cell. But look for the shooter, not just the dead guy
