Dave West
I have recently bought a MacGregor 25 and it came with an original slide-out galley. The problem is, I can't see much utility to it. Here are a couple of questions:1. How would you use an electric burner? Is this for shore power only? Wouldn't an alcohol stove make more sense? Or how about propane?2. There is a sink but no lines for freshwater or used gray water. What do other owners do? install a reservoir under the counter? Install a water bladder under the cockpit? Plumb in a gray water container under the sink?3. Should I throw it out and start over? The cabin is fairly small and I really don't see any good place to put in a galley area.If anyone could help me with the answer to even one of my questions I would be greatful.Thank you in advance,Dave West
