It has been a love/hate affair with the 10 windows on SV Hadley. After 48 years the seals failed, were removed and delivered to the glass shop to replace glass and reseal against the weather.
Got to the boat Tuesday, 28 days since I reinstalled the windows. One of the "fixed" windows had leaked a puddle on the counter. Arrrgh..
Removed the window and frame. Bed-it Butyl had spread nicely around the frame and adhered to the cabin fiberglass. The install was good. Removable but not easily. Thumbs up.
Poured water on the glass. The glass leaked like a babies diaper in a Grand Parents arms.
Back to the glass shop.
What to do while waiting for the window fix? Well it has been a year since I last checked my PFD live vests. How about you?
Look at the date on the inflator. Pull the vest out of the harness.
IF this is too much of a challenge, then I suggest you take the vest to a service center and have them do the work.
I inspect every year and every 5 years to before an extended passage, I will take the vest to a service center for a check-up. I figure safety equipment is the last thing you want to glitch when you call on it to function.
Hey, I hear the phone ringing. Hope it ti the glass shop with my window ready.
- Inspect all of the enclosed gear, like whistles... yes I test the whistle too.
- Is there a cutter attached?
- A light? My vest came with a "pylon light" and "Lume-On" lights that make the yellow tubes flash when in the water. Lume-On lights work... Battery in Pylon Light requires replacement. Glad I checked.
- Do the tubes hold air? Blow up manually (you will want to know that works before you go swimming.)
