What do you call the "Radiator Cap" on a marine diesel?
Jan 7, 2011
6,006
Oday 322 East Chicago, IN
I have a Yanmar 2GM20F engine in my O'Day 322, and the cap on the cooling tank (anti-freeze) needs to be replaced. I don't see a radiator cap listed on the parts list for this engine....do they call it something different (I realize there is no air-cooled "radiator" on this engine....
Or çan I use any old radiator cap from the auto parts store?
Greg
Oct 2, 2006
1,517
Jboat J24 commack
Its the same function as A radiator cap BUT for example mine is 7 PSI and matches up with old GMs
In marine it would be called as heat exchanger cap :)
NorSea 27 Az., Doing the To-Do list
From my 2GM20F parts manual.....
Published 2010/11 (Nov.)
Figure 26. COOLING FRESH WATER COOLER
REF. LEV. PARTS NO. DESCRIPTION
8 2 128397-44600 FILLER W/BALL
BUT, this looks like more than JUST the cap. You should be able to call the dealer and ask. This should give you a start.
Greg
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
its either 12 lbs or 13 lbs psi on the.... 2gm20f a cant remember which
Oday 35 and Mariner 2+2 Alexandria, VA
If you have the PSI that you need, amazon has them for about 7 bucks each.
Jan 7, 2011
6,006
That is pricey for sure and would try one for auto. Nick
yikes... I will have to check and see if I can a match for a tractor or auto...under $10 bucks compared to $70 for a marine cap!
Thanks everyone for the help. I found 1 reference to a "radiator cap" on Yanmar parts list, but then that part was superceded by a new part number with a description of a "Filler, with ball". Not sure if that is the cap, but it seems to be.
I did find this site with a cap listed for $17....
http://acemarinediesel.com/marine-engine-parts/yanmar-marine-parts/yanmar-129107-44590-radiator-cap/
Will take the old cap off and clean it up to see if there is a part number or a pressure setting on it.
Thanks again for the help.
Greg
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
take it to an auto shop/ or auto parts store and have it tested there they can tell you what the pressure is on that cap
Mar 30, 2013
700
I just call mine Rufus. It don't matter none though cause he don't come when I call.
