I own a ODay 23 circa 1974(actually it was definitely built 1974)and I am generally
quite pleased with my purchase in 2007. But, as perfection is hard to attain, I am having a significant issue with my jib.
(I love to say "jib" around my non-sailing friends as I know they are very impressed with my knowledge of the sea. I did read "Two Years Before the Mast.")
I highly recommend it.
In regard to my jib, no matter what route my working and lazy sheets take from the clew of the jib, when tacking the jib will not move across the bow without catching on something, rubbings or anything that will disallow my abilility to maintain speed.
I have three shrouds on either side of the mast; a jib/genoa lead block both starboard and port; safety rail with one lower rail.
I have run the sheets directly through the lead block to the cockpit - catches on hatch cover and if that is resolved on the mast.
I have run the sheets behind the third (stern)shroud - The attachment point of the sheets to the jib settles on the shround (usually one)and it usually takes sending someome forward to remove. Unfortunately, sailing single-handed means I'm the one fixing.
You name it, I've tried it.
I would very much appreciate an answer to the vexing question -
How Do I Properly Rig My Jib?
Thank you.
Thank you.
