What do do with smelly platic water tank?
119
Catalina 30 Edmonton
New owner of a C30. was winterized last fell. I started out with RV antifreeze, pumped that out in the spring. filled up my tanks with good clean city water. I ran low on water once so put in 10 gallons of so called good well water. Since the well water went in I have been using city water again but the odour coming from the tank is horrible. I researched last night including this site. No answer. What can I use to kill off whatever is in there? Vinegar? Bleach? Thanks ken
Try this:
archive search on "recommission" -- http://archives.sailboatowners.com/?fno=20&uid=73200280089 type in the word and hit search, read #5 This gets asked about once a week.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Bleach
One part bleach to 10 parts water.....let sit for several hours flush several time and should be good. My tanks on my new to me P36-2 were black. I flushed the tanks once with bleach let sit for about 10 hrs. flushed 2 times then filled half way and went in with my hand and scrubbed the sides. Then did a second bleach treatment, flushed several times and not a bit of oder and the tanks are squeeky clean. Greg
Ross
Jun 15, 2004
14,693
Water tanks can get funky for many reasons
and like swimming pools need some help to be clean. Each spring I refill my tanks (about 14 gallon ) and add a full gallon of chlorine bleach and pump it through the system and leave it for 24 hours, then I syphon all of the water out of the tank and refill with fresh and pump that through the system. I repeat this three times and taste the water. If I don't like what I have I do the whole routine again. If the tanks get funky in the summer the bleach goes in and the tanks get cleaned as discribed.
Dec 2, 1997
9,011
- - LIttle Rock
The right way
If you're only cleaning the tank, not the plumbing too... you're only doing half the job. Although most people think only in terms of the tank, the plumbing is actually the source of most foul water, because the molds, mildew, fungi and bacteria which cause it thrive in damp dark places, not under water. Many people—and even some boat manufacturers—believe that keeping the tanks empty reduce the problem, but an empty water tank only provides another damp dark home for those “critters.” To do it right, use a solution of 1 quart bleach/50 gal water....fill the tank, then turn on every faucet on the boat. When the water coming out smells strongly of bleach, turn off all the faucets, but leave the pump on to keep the system pressurized so the solution stays in the lines. Leave it in the system for at least 3 hours, but no longer than 24 hours. Then drain the tank through every faucet on the boat. Fill the tank again with clean water...drain again through every faucet. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart white vinegar/five gallons water and allow this solution to agitate in tank for several days. Drain through every faucet, then flush the system with clean fresh water. This will also get rid of any anti-freeze taste/smell. People have expressed concern about using this method to recommission aluminum tanks. While bleach (chlorine) IS corrosive, it’s effects are are cumulative. So the effect of an annual or semi-annual "shock treatment" is negligible compared to the cumulative effect of holding chlorinated city water in the tank for years. Nevertheless, it's a good idea to mix the total amount of bleach in a few gallons of water before putting it into a metal tank. Be sure to turn off the water heater at the breaker before beginning the recommissioning...do not turn it on again until recommissioning is complete. An annual or semi-annual recommissioning according to the above directions is all that should be necessary to keep your water tasting and smelling as good as anything that comes out of any faucet on land. If you need to improve on that, install a water filter. Just remember that a filter is not a substitute for cleaning out the system, and that filters require regular inspection and cleaning or replacement. To keep the water system cleaner longer, use your fresh water...keep water flowing through system. The molds, fungi, and bacteria only start to grow in hoses that aren't being used. Before filling the tank each time, always let the dock water run for at least 15 minutes first...the same critters that like the lines on your boat LOVE the dock supply line and your hose that sit in the warm sun, and you certainly don't want to transfer water that's been sitting in the dock supply line to your boat's system. So let the water run long enough to flush out all the water that's been standing in them so that what goes into your boat is coming straight from the water main.
